Melomania TouchCommon issuesMy Melomania Touch connects to my phone and plays music without a problem, but the Melomania app doesn’t seem to connect and show battery level etc.
Melomania Touch
If you face a problem trying to get a pair of Melomania Touch to connect with the app, then this will be because they haven't been correctly paired. The way our True Wireless technology works, means that both earbuds should appear in your Bluetooth device list, but this isn’t obvious unless you know about it. Learning from early user feedback, we suggest following the steps in our pairing guides to be sure.
The Melomania App is designed for Melomania Touch and not Melomania 1, so if you try and connect a pair of Melomania 1's to the app, the app will not function.
Unfortunately, it is impossible for us to make Melomania 1 retro-compatible with the app, as it was designed over a year ago and was never designed to work with an app.
